1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: about mca
Date: Fri, 2 Jun 2006 11:50:10 +0800
I got the following error code when I compiled mca under windows.
>> mcacompile
 This is mex, Copyright 1984-2001 The MathWorks, Inc.
-> Default options filename found in C:\Documents and Settings\Administrator\Application Data\MathWorks\MATLAB\R12
->    Options file           = C:\Documents and Settings\Administrator\Application Data\MathWorks\MATLAB\R12\mexopts.bat
      MATLAB                 = C:\MATLAB
->    COMPILER               = cl
->    Compiler flags:
         COMPFLAGS           =  -DEPICS_DLL_NO -DWIN32 -c -Zp8 -G5 -W3 -DMATLAB_MEX_FILE -nologo -DDB_TEXT_GLBLSOURCE
         OPTIMFLAGS          = -O2 -Oy- -DNDEBUG
         DEBUGFLAGS          = -Zi -Fd"mca.pdb"
         arguments           =  -DDB_TEXT_GLBLSOURCE -DGCC -DEPICS_DLL_NO -ID:/work/EPICS/EPICS/base/include -ID:/work/EPICS/EPICS/base/include/os/win32-x86
         Name switch         = /Fo
->    Pre-linking commands   =
->    LINKER                 = link
->    Link directives:
         LINKFLAGS           = /dll /export:mexFunction /MAP /LIBPATH:"C:\MATLAB\extern\lib\win32\microsoft\msvc60" libmx.lib libmex.lib libmatlbmx.lib libmat.lib /implib:_lib6065.x
         LINKFLAGSPOST       =
         Name directive      = /out:"mca.dll"
         File link directive = D:\work\EPICS\EPICS\base\lib\WIN32\Com.lib D:\work\EPICS\EPICS\base\lib\WIN32\ca.lib
         Lib. link directive =
         Rsp file indicator  = @
->    Resource Compiler      = rc /fo "mexversion.res"
->    Resource Linker        =
--> "cl  -DDB_TEXT_GLBLSOURCE -DGCC -DEPICS_DLL_NO -ID:/work/EPICS/EPICS/base/include -ID:/work/EPICS/EPICS/base/include/os/win32-x86  -DEPICS_DLL_NO -DWIN32 -c -Zp8 -G5 -W3 -DMATLAB_MEX_FILE -nologo -DDB_TEXT_GLBLSOURCE /Fomca.obj -IC:\MATLAB\extern\include -IC:\MATLAB\simulink\include -O2 -Oy- -DNDEBUG mca.cpp"
mca.cpp
--> "cl  -DDB_TEXT_GLBLSOURCE -DGCC -DEPICS_DLL_NO -ID:/work/EPICS/EPICS/base/include -ID:/work/EPICS/EPICS/base/include/os/win32-x86  -DEPICS_DLL_NO -DWIN32 -c -Zp8 -G5 -W3 -DMATLAB_MEX_FILE -nologo -DDB_TEXT_GLBLSOURCE /FoMCAError.obj -IC:\MATLAB\extern\include -IC:\MATLAB\simulink\include -O2 -Oy- -DNDEBUG MCAError.cpp"
MCAError.cpp
--> "cl  -DDB_TEXT_GLBLSOURCE -DGCC -DEPICS_DLL_NO -ID:/work/EPICS/EPICS/base/include -ID:/work/EPICS/EPICS/base/include/os/win32-x86  -DEPICS_DLL_NO -DWIN32 -c -Zp8 -G5 -W3 -DMATLAB_MEX_FILE -nologo -DDB_TEXT_GLBLSOURCE /FoChannel.obj -IC:\MATLAB\extern\include -IC:\MATLAB\simulink\include -O2 -Oy- -DNDEBUG Channel.cpp"
Channel.cpp
--> "cl  -DDB_TEXT_GLBLSOURCE -DGCC -DEPICS_DLL_NO -ID:/work/EPICS/EPICS/base/include -ID:/work/EPICS/EPICS/base/include/os/win32-x86  -DEPICS_DLL_NO -DWIN32 -c -Zp8 -G5 -W3 -DMATLAB_MEX_FILE -nologo -DDB_TEXT_GLBLSOURCE /FoChannelAccess.obj -IC:\MATLAB\extern\include -IC:\MATLAB\simulink\include -O2 -Oy- -DNDEBUG ChannelAccess.cpp"
ChannelAccess.cpp
--> "rc /fo "mexversion.res"  "C:\MATLAB\extern\include\mexversion.rc""
    Contents of 6065_tmp.rsp:
 D:\work\EPICS\EPICS\base\lib\WIN32\Com.lib D:\work\EPICS\EPICS\base\lib\WIN32\ca.lib mca.obj D:\work\EPICS\EPICS\base\lib\WIN32\Com.lib D:\work\EPICS\EPICS\base\lib\WIN32\ca.lib MCAError.obj D:\work\EPICS\EPICS\base\lib\WIN32\Com.lib D:\work\EPICS\EPICS\base\lib\WIN32\ca.lib Channel.obj D:\work\EPICS\EPICS\base\lib\WIN32\Com.lib D:\work\EPICS\EPICS\base\lib\WIN32\ca.lib ChannelAccess.obj  D:/work/EPICS/EPICS/base/lib/win32-x86/Com.lib  D:/work/EPICS/EPICS/base/lib/win32-x86/ca.lib mexversion.res
--> "link /out:"mca.dll" /dll /export:mexFunction /MAP /LIBPATH:"C:\MATLAB\extern\lib\win32\microsoft\msvc60" libmx.lib libmex.lib libmatlbmx.lib libmat.lib /implib:_lib6065.x  @6065_tmp.rsp "
Microsoft (R) Incremental Linker Version 6.00.8168
Copyright (C) Microsoft Corp 1992-1998. All rights reserved.
   Creating library _lib6065.x and object _lib6065.exp
Channel.obj : error LNK2001: unresolved external symbol _dbr_value_size
Channel.obj : error LNK2001: unresolved external symbol _dbr_size
Channel.obj : error LNK2001: unresolved external symbol _dbf_text_dim
mca.dll : fatal error LNK1120: 3 unresolved externals
  C:\MATLAB\BIN\WIN32\MEX.PL: Error: Link of 'mca.dll' failed.
??? Error using ==> mex
Unable to complete successfully
Error in ==> D:\work\matlab\mca\mcacompile.m
On line 10  ==>     -v
VC version is 6.0
Matlab version is 6.2
EPICS BASE is 3.14.6
The mcacompile.m file is,
%MEXCOMMAND Make mca.mexglx from mcamain.cpp
%cd /matlab/toolbox/mca
mex mca.cpp MCAError.cpp Channel.cpp ChannelAccess.cpp ...
    D:/work/EPICS/EPICS/base/lib/win32-x86/Com.lib ...
    D:/work/EPICS/EPICS/base/lib/win32-x86/ca.lib ...
    -DDB_TEXT_GLBLSOURCE -DGCC -DEPICS_DLL_NO ...
    -ID:/work/EPICS/EPICS/base/include ...
    -ID:/work/EPICS/EPICS/base/include/os/win32 ...
    -v
Best wishes and regards,
Huangsong
        [email protected]
          2006-06-02
** Huang song
** Control Group of Accelerator center
** Institute of High Energy Physics
** P.O. Box 918(10)
** Beijing 100049, P.R. CHINA
** Fax: +86-10-8823-6190
** E-mail: [email protected]
Prev: install Epicsbase3.14.8.2 on WinXP question Gan Quan
Next: need help btanu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
