Hi Ron,
For the TDS3xx support (code mostly taken Ben Franksen's TDS540 support), we do the conversion in the "convert" routine provided in the gpibCmd structure (see page 9 of:
http://www.aps.anl.gov/epics/modules/soft/asyn/R4-6/devGpib.pdf).
The convert routine is done before record processing - it takes the string from the gpib driver, parses it, and fills in bptr and nord. For an example, you can download the tds3xx GPIB support from the EPICS hardware support page (unfortunately, it's still 3.13) or in your case, look at /afs/slac/package/epics/R3.13.6/site/src/tdsGpib.
Better to look at Nick DiMonte's support first.
Stephanie
> -----Original Message-----
> From: Chestnut, Ronald P. [mailto:[email protected]]
> Sent: Wednesday, June 21, 2006 9:50 AM
> To: [email protected]
> Subject: Question on supporting GPIB waveform acquisition
> from a variety of scopes
> We are moving our legacy VMS-based GPIB control and
> acquistion to EPICS. SLAC uses a number of different scopes
> from different vendors. The more modern scopes, like the
> Tektronix TDS3000 support GPIB commands which return a
> "preamble" with the waveform data. This preamble contains,
> among other things, scaling information needed for proper
> display. Other, older scopes, require that each tidbit of
> information be requested individually.
> The TDS3000 "WAVFrm?" command returns:
> Write returned 0 and wrote 7 bytes
> Read returned 0 and stopped for 1 read 1024 bytes
> Buffer: 2;16;BIN;RI;MSB;10000;"Ch2, AC coupling, 5.0E-2
> V/div, 4.0E-7 s/div, 10000 points, Sample
> mode";Y;4.0E-10;0;-2.08E-6;"s";7.8125E-6; 0.0E0;1.5744E4;"V";#520000
> Has someone addressed the problem of a generic method to
> receive these interesting strings and parse the information out?
> I can see a few ways to do each device with GENSUB or driver
> code or even (my favorite hammer) some SEQ program, but am
> hoping someone has a clever solution already.
> Ron Chestnut
- Question on supporting GPIB waveform acquisition from a variety of scopes Chestnut, Ronald P.
Re: Question on supporting GPIB waveform acquisition from a variety of scopes Luedeke Andreas
RE: epics php Jeff Hill
<2006>
2025
2026
[Fwd: Re: Question on supporting GPIB waveform acquisition from a variety of scopes] Ned Arnold
<2006>
2025
2026
