1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequencer embedded C code question
To: [email protected]
Date: Thu, 29 Jun 2006 15:44:21 -0400
I forgot to mention that we are using seq 2.0.11 (I recently updated
everything on this particular machine).
On 6/29/06, Jiro Fujita <[email protected]> wrote:
Hello,
This is probably really an elementary question, but we have been
trying to interface an RS-232 device to EPICS soft IOC on Linux.  We
are using EPICS 3.14.8.2 with Asyn 4.6 (devGpib) via serial port.  The
response from the device looks like this:
1+32.23
2-50.01
3+23.98
It has five channels, reads one value a second, contiunally sending
the message through the serial port (that seems to be a typical thing
here at STAR/BNL).
We need to have the data sorted into five different PVs, based upon
the channel names.  In the end, the example above should look like
this:
channel 1: 32.23
channel 2: -50.01
channel 3: 23.98
Because we need the channel number and the + or - sign in the raw
data, I am taking the data into the IOC as string, having the
sequencer split the channel number, based upon that, we are trying to
put the value into the database.
Well, so far, we have not been successful in writing the sequencer
code.  To the best of my knowledge, the sequencer cannot manipulat
text strings, we are escaping all of that to C within the sequencer
code, but we are getting a number of errors upon make.
Here is the error message we are getting:
make[3]: Entering directory
`/home/sysuser/epics3.14.8.2/hygrometerApp/hygrometerApp/src/O.linux-x86'
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux
-D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I..
-I../../../include/os/Linux -I../../../include
-I/home/sysuser/epics3.14.8.2/base-3.14.8.2/../modules/soft/seq-2.0.11/include/os/Linux
-I/home/sysuser/epics3.14.8.2/base-3.14.8.2/include/os/Linux
-I/home/sysuser/epics3.14.8.2/modules/soft/asyn/4-6/include/os/Linux
sncProgram.c
../sncExample.stt:34: warning: type defaults to `int' in declaration of `rob'
../sncExample.stt:34: conflicting types for `rob'
../sncExample.stt:9: previous declaration of `rob'
../sncExample.stt:35: `roba' undeclared here (not in a function)
../sncExample.stt:35: syntax error before "v"
../sncExample.stt:36: warning: type defaults to `int' in declaration of `wa1'
../sncExample.stt:36: conflicting types for `wa1'
../sncExample.stt:29: previous declaration of `wa1'
../sncExample.stt:36: braced-group within expression allowed only
inside a function
../sncExample.stt:36: syntax error before string constant
../sncExample.stt:37: warning: type defaults to `int' in declaration of `z'
../sncExample.stt:37: initializer element is not constant
../sncExample.stt:37: warning: data definition has no type or storage class
make[3]: *** [sncProgram.o] Error 1
make[3]: Leaving directory
and here is the code:
program snchygrometer
%%#include <ctype.h>
%%#include <stdlib.h>
%%#include <stdio.h>
   %%char rob[10] ;
   char *roba;
   assign roba to "rawdata" ;
   monitor roba ;
   float ch1 ;
   float ch2 ;
   float ch3 ;
   float ch4 ;
   float ch5 ;
   assign ch1 to "PV1";
   assign ch2 to "PV2";
   assign ch3 to "PV3";
   assign ch4 to "PV4";
   assign ch5 to "PV5";
   int v ;
   float z ;
   %%extern char *wa1 ;
   %%char *sign="+-" ;
   rob=&roba
   v=rob[0];                 /*Get first char from string*/
   wa1=strpbrk(rob, "+-");   /*Break string at +-,rest is wa1*/
   z=(float)wa1;             /*convert string to float z*/
ss ss1 {
   state state1 {
      when (    v==1) {
          ch1 = z; pvPut(ch1);
      } state state2
   state state2 {
      when (    v==2) {
          ch2 = z; pvPut(ch2);
      } state state3
   state state3 {
      when (    v==3) {
          ch3 = z; pvPut(ch3);
      } state state4
   state state4 {
      when (    v==4) {
          ch4 = z; pvPut(ch4);
      } state state5
   state state5 {
      when (    v==5) {
          ch5 = z; pvPut(ch5);
      } state state1
What are we doing wrong?? The C code embedded in the sequencer code above compiles without any issues under gcc. Being new to sequencer/state notation language, we are lost here...
RE: Sequencer embedded C code question Laznovsky, Michael
Sequencer embedded C code question Jiro Fujita
Prev: Sequencer embedded C code question Jiro Fujita
Next: RE: Sequencer embedded C code question Laznovsky, Michael
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
