1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: error while loading shared libraries
To: Stefan Bruins <[email protected]>
Cc: TECHTALK Tech-Talk <[email protected]>
Date: Fri, 30 Jun 2006 09:26:20 -0500
On Jun 30, 2006, at 7:02 AM, Ernest L. Williams Jr. wrote:
On Fri, 2006-06-30 at 10:21 +0200, Bruins, Stefan wrote:
When I try to put on the ASYN-4.3 driver on a linux computer a MAKE command
I get the error:
/opt/epicsbase3-14/bin/linux-x86/dbToRecordTypeH: error while loading shared
libraries: libdbStaticHost.so: cannot open shared object file: No such file
or directory
What am I doing wrong here?
Has your EPICS base been moved (renamed) or mangled after it was built?
Check that "/opt/epicsbase3-14/lib/linux-x86/libdbStaticHost.so" exists.
Then check that you have your LD_LIBRARY_PATH setup to point to the
location of your EPICS shared libraries
You shouldn't have to deal with LD_LIBRARY_PATH issues if you leave the libraries where they were built.
Also -- not that this has anything to do with the problem mentioned above, but ASYN-4.3 is getting to be a rather old release.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
error while loading shared libraries Bruins, Stefan
Re: error while loading shared libraries Ernest L. Williams Jr.
Prev: Re: error while loading shared libraries Ernest L. Williams Jr.
Next: Lesson learned: LINR, LINEAR, SLOPE, R3.13, R3.14, breakpoint tables Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
