1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: question about dbLoadTemplate()
To: [email protected]
Date: Fri, 30 Jun 2006 13:00:28 -0400
Standard way to use dbLoadTemplate()is
1. ***st.cmd***
cd $TOP
dbLoadTemplate( "db/Test.substitutions")
2. Test.substitutions has links to templates files
file db/Test1.template ...
file db/Test2.template ...
So Test.substitutions and templates (Test1.template and Test2.template)
files should be in the same directory (in this example top/db/ )
How can it be used if the files are in the different directories?
I found a way in vxWorks.
For example, Test.substitutions is in
/ade/epics/iocCommon/"IOCName"/Data
and Test.template is in /ade/epics/iocTop/R3.14.7/SystemX/R2-0/db. Then
1. st.cmd has
SubstitutionPath=malloc( 100)
sprintf SubstitutionPath, "/ade/epics/iocCommon/%s/Data",iocName
nfsMount nfsServer,SubstitutionPath,"/SubPath"
TemplatePath=malloc( 100)
sprintf TemplatePath, "/ade/epics/iocTop/R3.14.7/SystemX/R2-0/db"
nfsMount nfsServer, TemplatePath,"/TemPath"
cd "/SubPath"
dbLoadTemplate("Test.substitutions")
2. Test.substitutions file has
file TemPath/Test1.template ...
(!!! "file top/db/Test1.template ..." doesn't work)
It works. But that is spaghetti's way and I suppose it will not work in
Windows and Linux.
So question:
Has anyone done something similar (to have template and substitutions
files in different directories)?
Thanks, Andrei.
Re: Presentations from the last collaboration meeting. Andrew Johnson
Prev: Lesson learned: LINR, LINEAR, SLOPE, R3.13, R3.14, breakpoint tables Kay-Uwe Kasemir
Next: RE: question about dbLoadTemplate() Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Presentations from the last collaboration meeting. Andrew Johnson
Next: RE: Driver for SBS IP-OPTOIO-8 Mark Rivers
