1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Misaligned protocol rejected, Java client, restarts
To: <[email protected]>
Date: Thu, 6 Jul 2006 16:37:03 -0600
Hello.  I'm working on a Java/Eclipse program using the Java based Eclipse client.  It mostly books value callbacks from tree views, and polls values from a table view.  It is a fairly large dataset (a couple of thousand PV's).
It seems to work fine the majority of the time, but often when you close the program and restart it, it will disconnect shortly after coming up, and the server will throw a "Missaligned protocol rejected" followed by a "forcing disconnect".
Two related questions:
1. What causes this error.  Is there a common thing I may be doing wrong?
2. Is there something that needs to be done when shutting down a Java program, so the client disconnects and reconnects cleanly?
Harley.
Harley Nelson
Echostar Communications
[email protected]
_________________________________
SISNA...more service, less money.
http://www.sisna.com/exclusive/
RE: Misaligned protocol rejected, Java client, restarts Jeff Hill
Java CA 101, Re: Misaligned protocol rejected, Java client, restarts Kay-Uwe Kasemir
Prev: Widgets with unresolved PVs Timothy Southern
Next: RE: Misaligned protocol rejected, Java client, restarts Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: ASYN UDP broadcasts Eric Norum
