1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: record programming and share oblects
To: [email protected]
Date: Fri, 07 Jul 2006 13:43:21 -0400
I found way to do that.
# dbDevice.db
record( longout, "$(Place):$(Device):TimeEvent"){
	field(FLNK,"$(Place):$( Device):TimeEventString")
	field(SCAN, "Passive")
	field(PINI,"YES")
	field(DOL,"46")
	field(OMSL,"supervisory")
record( stringout, "$(Place):$( Device):TimeEventString"){
	field(VAL,"$(Place):$( Device):TimeEvent")
	field(OUT,"$(Place):$(Hardware):TimeEvent.DOL CA")
	field(FLNK,"$(Place):$( Device):TimeEventProc")
	field(PINI,"YES")
	field(DOL,"$(Place):$( Device):TimeEvent")
record( ao, "$(Place):$( Device):TimeEventProc"){
	field(OUT,"$(Place):$(Hardware):TimeEvent.PROC CA")
	field(PINI,"YES")
	field(DOL,"1")
#dbHardware.db
record( longout, "$(Place):$(Hardware):TimeEvent"){
	field(DTYP,"SMLong")
	field(OUT,"@$(Place)$(Hardware)TimeEvent")
#	field(PINI,"YES")
#	field(DOL,"46")
	field(OMSL,"closed_loop")
#st.cmd
dbLoadRecords("db\ dbHardware.db","Place=Test_Diag,Hardware=TestComputer")
dbLoadRecords("db\ dbDevice.db","Place=Test_Diag,Device=Device01,,Hardware=TestComputer")
dbLoadRecords("db\ dbDevice.db","Place=Test_Diag,Device=Device02,Hardware=TestComputer")
dbLoadRecords("db\ dbDevice.db","Place=Test_Diag,Device=Device0N,Hardware=TestComputer")
Thanks, Andrei.
Sent: Friday, July 07, 2006 1:33 PM
Subject: record programming and share oblects
Sometimes IOC has share object. As example, ADC-digitizer has 2 channels
and once delay from external trigger or sampling rate for both channels.
I can handle that easy in C/C++ like system has 4 objects
- Device 1 has pointer pDAQ (middle layer)
- Device 2 has pointer pDAQ (middle layer)
- pDAQ has pointer pADC and handles sharing
- and ADC
In pDAQ I can provide simple logic like
- set only the latest value (according timestamp)
- Device 1 catches pDAQ and another Device 2 waits its turn (it is
useful for long measuring)
or a little complicated ...
Client (OPI) has "virtual device with full possibilities", readback
values are always correct, and (PVs) set is the same. So I don't need to
have deal with PV like ***.Device1&2.Delay or ***.Device5&8&12.Delay
I handle just sets of Devices and ONE set PVs for that Device type! That
gives EDM screen with just one macros Device name!
I understand that I can't have all features :-(
But maybe I can have feature with "ONE set PVs per Device type"?
Ok, I am ready to handle "Device1&2.Delay" on IOC level. But I go to
infinite loop with FWD or INP (with CA) :-(
Have anyone found way or trick to simplify life?
Thanks, Andrei.
record programming and share oblects Liyu, Andrei
Prev: record programming and share oblects Liyu, Andrei
Next: error while building ChannelArchiver2.8.1 in RedHat9 Liu Shu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
