1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: about add/delete record in process database during operation
To: afree <[email protected]>
Date: Wed, 12 Jul 2006 09:49:19 -0500
afree wrote:
Some epics technical documents reported that the epics base 3.14.x has the ability of add/delete record in processes database during operation, but I found little information about how to do this in the AppDevGuide.pdf and some other documents. Is there anybody who has the experience of this could show some simple example of how to do this. thanks!
Which document(s) imply this? It is *not* possible to add or delete records to an after the call to iocInit() from the startup script. In the future it might become possible to add new record instances, but I don't think the current code-base will ever permit deleting records (that would need a complete rewrite of IOC Core which could not be made compatible with existing record types and device support).
- Andrew
Not everything that can be counted counts,
and not everything that counts can be counted.
  -- Albert Einstein
about add/delete record in process database during operation afree
Prev: Re: EPICS interface to APS Conventional Facilities Elder Matias
Next: RE: Matlab interfaces Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: about add/delete record in process database during operation afree
Next: Dev lib off-board register access Rees, NP (Nick)
