1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA communication problems
To: tech talk <[email protected]>
Date: Mon, 17 Jul 2006 14:39:12 -0400
Hi:
I have some problems of communication between an IOC and a client, both
running on different machines on the same subnetwork on a similar
environment (Epics v 13.4.7 under linux redhat 9.0 kernel 2.4.20-8).
At the beginning of the startup of the IOC, process variable values can
be got without problems from a client (either a simple command line or a
php script), but after a while, the data is not available any more and
the following message shows up on the IOC side :
CAS: request from 192.168.101.21:55894 => "bad resource ID"
Are there some pure-Java-CA-clients involved?
Does PHP use the pure Java client, or the C/C++ CA client?
I've seen "bad resource ID" messages on IOCs that were
accessed by the pure java CA client. For what it's worth,
they looked like this:
CAS: request from 172.31.75.12:34983 => "bad resource ID"
CAS: Request from 172.31.75.12:34983 => cmmd=1 cid=0x756 type=20 count=1 postsize=16
CAS: Request from 172.31.75.12:34983 => available=0x6b4 N=0 paddr=0x0
CAS: forcing disconnect from 172.31.75.12:34983
CAS: request from 172.31.75.12:35274 => "bad resource ID"
CAS: Request from 172.31.75.12:35274 => cmmd=1 cid=0x895 type=20 count=1 postsize=16
CAS: Request from 172.31.75.12:35274 => available=0x81a N=0 paddr=0x0
CAS: forcing disconnect from 172.31.75.12:35274
-Kay
CAS: Request from 192.168.101.21:55894 => cmmd=12 cid=0xffffffff type=0
count=0 postsize=0
CAS: Request from 192.168.101.21:55894 => available=0x1 N=0
paddr=(nil)
CAS: forcing disconnect from 192.168.101.21:55894
Would someone have an idea of what's going on ?
I have no guesses at this point, but instead a few questions.
O Is this Linux running on a typical Intel x86 computer?
O What does the output from the "casr 10" command, typed into the IOC's
console when the failure is occurring, provide?
O I would also look at the cpu, memory, and socket consumption in the IOC's
host using top and netstat.
O Is 192.168.101.21 the IP address of the host for the client that isn't
able to connect, or does the host IP in the message vary?
O Does the IOC appear to be functioning correctly in other respects when
this occurs?
O Does the IOC have any layered products (such as drivers) installed when
this occurs?
Jeff
-----Original Message-----
Sent: Monday, July 17, 2006 6:08 AM
To: [email protected]
Subject: CA communication problems
Hello,
count=0 postsize=0
paddr=(nil)
Thanks for your help
Christophe
RE: CA communication problems Jeff Hill
Prev: RE: CA communication problems Jeff Hill
Next: Re: CA communication problems Christophe Moins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
