1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS Vacancies at Diamond Synchrotron Light Source
To: <[email protected]>
Date: Wed, 19 Jul 2006 14:16:09 +0100
Hello All,
Diamond Synchrotron Light Source, http://www.diamond.ac.uk/  , the largest scientific facility to be built in the UK for nearly thirty years, has exciting opportunities for software and software systems engineers to participate in cutting edge research, and software development using EPICS.
These roles will be based in the Control Systems Group which has responsibilities for accelerator and beamline control systems on the Diamond facility. Control systems are realised using EPICS,  with VME and VxWorks together with embedded Linux systems for the hardware interface layer and  Linux workstations for all development and operational systems.
The following positions are available:
SOFTWARE SYSTEMS ENGINEER : PHOTON BEAMLINES (X2) Ref. DIA0221
These positions will work closely with a team of scientists and engineers to specify and develop software to deliver ultra stable x-ray beams from the Diamond Storage Ring to the experimental samples. These roles will work in a distributed, heterogeneous computing environment, using embedded systems for direct control of the hardware and Linux workstations for the operator interfaces. Embedded applications are coded in C or built using the EPICS control system toolkit, and the Linux applications use a combination of C, Java and scripting languages.
http://www.diamond.ac.uk/Jobs/CurrentVacancies/Technical/DIA0221.htm
SOFTWARE ENGINEER: EPICS Toolkit Core Development Ref. DIA0220
This position will involve working with scientists and engineers on the overall design and specification for future versions of the EPICS toolkit to support the general needs of the EPICS collaboration and the specific requirements of Diamond.
http://www.diamond.ac.uk/Jobs/CurrentVacancies/Technical/DIA0220.htm
Network Administrator Ref. DIA0219
This position will manage and develop the network installation to support the development and operation of the accelerators and experimental stations . The successful candidate will be expected to have responsibility for technical input to network design, implementation and operational support, together with an appreciation of the operation requirements for a large Linux based distributed computing environment.  This position is available at Administrator Level or Senior Administrator Level. At senior level it will also include management and planning for network administration together with the management and planning of a  team of Linux System administrators.
http://www.diamond.ac.uk/Jobs/CurrentVacancies/Technical/DIA0219.htm
For all positions candidates will need to demonstrate an excellent understanding of computing technology. They should have a good honours degree in physics, electronic engineering or computer science. Diamond can offer the successful candidates comprehensive benefits, a competitive salary (dependant upon qualifications and relevant experience), and a relocation package where applicable.
Regards.
Mark Heron
Prev: Re: CA communication problems Christophe Moins
Next: Does anyone have a driver for an ISEG HV Module? Thompson, David H.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
