1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re:Does anyone have a driver for an ISEG HV Module?
To: <[email protected]>
Date: Mon, 24 Jul 2006 09:55:26 +0100
David,
At Diamond, we intend to use the VHS401p for XBPM biasing.  Your VHS402n
is of the same family and has the same software interface.
I have developed a driver targeted at vxWorks and all the necessary
EPICS support (currently R3.13.9).
Most of the hard work has been completed, with sufficient functionality
to enable a programmed voltage/current output. I'm presently adding
channel event and channel group support - also developing an EDM gui.
I have not yet added support for changing the module base address, as
the default byte-wise address of 0x4000 (A16 address space) is ok for
us.
Unusually, analogue values are read/written directly via single
precision floating point register (4 bytes wide); all access to the card
is by 16 bit word read/write, so floats (IEEE-754) must be accessed in
two operations, high word and low word.  Even so, the board's firmware
appears to have been well designed.
If it helps, I could tar the support module as it stands and email it to
you - just let me know.
Best regards,
Ian Gillingham
Diamond Light Source
-----Original Message-----
Subject:	Does anyone have a driver for an ISEG HV Module?
<mailto:thompsondh%40ornl.gov> >
Date:	Fri, 21 Jul 2006 08:38:27 -0400
Looking for a driver for an ISEG VHS402n HV Module. This is a VME card
that we are evaluating for our BLM application.
Prev: Off -Line Storage of Archiver Data - Request for Information Steven Banks
Next: Re: Off -Line Storage of Archiver Data - Request for Information Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Does anyone have a driver for an ISEG HV Module? Thompson, David H.
Next: How to change medm windows title + windows manager Emmanuel Mayssat
