1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: communication with rs485 multidrop device and command/response protocol
To: <[email protected]>, "TECHTALK Tech-Talk" <[email protected]>
Date: Wed, 26 Jul 2006 08:15:17 -0500
You should be able to do this using an "interpose interface" in asyn.  The interpose interface would take the "addr" field of the multidrop device, and call the underlying port driver to send the "ADR xxx" command.  It would then call the port driver to send the rest of the command/response.
I believe this is how David Kline implemented asyn support for the Love controllers.
Mark Rivers
Sent: Wed 7/26/2006 2:06 AM
To: TECHTALK Tech-Talk
Subject: communication with rs485 multidrop device and command/response protocol
i want to communicate with devices connected in RS485 multidrop and supports standard command/response protocol.to select a device first i have to send ADR xxx command. i have written a driver using asyn,but it can talk with only one device at a time.is there any other driver to support multidrop device with command/response protocol.IPAC is there but it is for canbus or profibus.
TANUSHYAM BHATTACHARJEE
SCIENTIFIC OFFICER
VARIABLE ENERGY CYCLOTRON CENTRE
1/AF BIDHANNAGAR ,SALTLAKE ,KOLKATA-64
email:[email protected]
Phone #23371230/31/32/33/34 Extn: 2304
Fax: 91 33 3346871
communication with rs485 multidrop device and command/response protocol btanu
Prev: communication with rs485 multidrop device and command/response protocol btanu
Next: Re: dol->name Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Allen-Bradley VME Scanner Module 6008 Luchini, Kristi
