1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: build multiple tops?
To: Geoff Savage <[email protected]>
Cc: TECHTALK <[email protected]>
Date: Fri, 28 Jul 2006 10:34:09 -0700
In my case, I use environment variable and "gmake -e" to overwrite make
variables and settings located in configure/RELEASE.
The reason I use this make option is exactly for the same purpose you
want to use it: "easy" upgrade of epics release or many builds of same
epics release.
FYI,
Emmanuel
On Fri, 2006-07-28 at 12:00 -0500, Geoff Savage wrote:
> Hi,
> When I use a new epics release I need to go into each top area,
> modify the configure/RELEASE file, do an uninstall, and then gmake.
> Are there Makefile rules available to simplify this process?
> Thanks,  Geoff
build multiple tops? Geoff Savage
Prev: build multiple tops? Geoff Savage
Next: Moxa N-Port, ASYN and IOC Exit John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: build multiple tops? Andrew Johnson
