1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem building base 3.14.8.2 on Win32
To: Douglas Pearson <[email protected]>
Date: Tue, 01 Aug 2006 11:33:41 +0500
during build it copies exe and required dll and obj in bin  as well as O.win32-x86 directory...i think
you have to modify some files in configure to do it correctly under windows as follows
1.base-3.14.8.2\configure\RULES_BUILD
line no 330
ifdef WIN32
ifdef BORLAND
@$(INSTALL_PRODUCT) -d -m 555 $<* $(INSTALL_BIN)
else
@$(INSTALL_PRODUCT) -d -m 555 $< $(INSTALL_BIN)
endif
endif
2.base-3.14.8.2\configure\os\CONFIG_SITE.win32-x86.win32-x86 to select proper compiler
you may encounter some other problem in makeBaseApp.pl.but clear it first
thnaks
 tanushyam
TANUSHYAM BHATTACHARJEE
SCIENTIFIC OFFICER
VARIABLE ENERGY CYCLOTRON CENTRE
1/AF BIDHANNAGAR ,SALTLAKE ,KOLKATA-64
email:[email protected]
Phone #23371230/31/32/33/34 Extn: 2304
Fax: 91 33 3346871
----- Original Message -----
Date: Tuesday, August 1, 2006 6:14 am
Subject: Problem building base 3.14.8.2 on Win32
> I'm trying out EPICS for the first time and trying to build it on
> Windows.After seeing the posts about Visual Studio 8 (2005), I've
> switched to using
> Visual Studio 7 (.NET 2003) and made the change to
> configure/RULES_BUILD as
> described in the known issues.
> With that I've got everything to build and com.dll even installs
> itself now.
> However, the next error I'm getting is:
> ..\\..\\..\\..\\bin\\win32-x86\\antelope.exe -l -d ../parse.y
> make[4]: ..\\..\\..\\..\\bin\\win32-x86\\antelope.exe: Command not
> foundmake[4]: *** [parse.c] Error 127
> make[4]: Leaving directory
> `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex/O
> .win32-x86'
> make[3]: *** [install.win32-x86] Error 2
> make[3]: Leaving directory
> `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex'
> The odd thing i! s that an
RE: Problem building base 3.14.8.2 on Win32 Douglas Pearson
Prev: Re: Could not connect to EPICS home most of the time btanu
Next: RE: Problem building base 3.14.8.2 on Win32 Douglas Pearson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Problem building base 3.14.8.2 on Win32 Douglas Pearson
