1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Porting EPICS to NetBSD
To: "Andrew Johnson" <[email protected]>, "David Dudley" <[email protected]>
Cc: <[email protected]>
Date: Tue, 15 Aug 2006 15:45:55 -0700
Hi Andrew,
Nice instructions!  We pretty much did those same steps when we ported EPICS 3.14.8.2 to VMS a few months ago.
Maybe add two more steps:
* Change base/startup/EpicsHostArch and EpicsHostArch.pl for the new arch.
* Add base/documentation/README.<arch> if special instructions are needed.
Also, I recommend that David get the latest CVS snapshot instead of the Jan 3.14.8.2 tar.  It will make it easier for you to accept the patch file (in case David needs to make changes other than those you list in the instructions - hopefully not).
Stephanie Allison
Re: Porting EPICS to NetBSD Andrew Johnson
Prev: Re: Porting EPICS to NetBSD Andrew Johnson
Next: Re: Porting EPICS to NetBSD David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Porting EPICS to NetBSD Eric Norum
