1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Porting EPICS to NetBSD
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Wed, 16 Aug 2006 10:46:29 -0700
You can have 2 control systems.
One with fast response time and PLC based.
The other one with EPICS (and PLCs reporting their status to EPICS).
Ofentimes, skills to build both of those control systems are different.
Instead of converting your hardware in IOCs, you may want to just had an
IOC (computer + EPICS) that can interface with it. This allow for smooth
transition. There are several PCI MODBUS cards available on the market.
In any case, it seems you have a lot of programming to do but that is no
different from what we are all am doing ;-)
Emmanuel
EPICS can work and all the equipment you need to connect.
On Wed, 2006-08-16 at 10:11 -0500, David Dudley wrote:
> into some of our PLC equipment in order to convert them into IOC's themselves.
Re: Porting EPICS to NetBSD David Dudley
Prev: Re: Porting EPICS to NetBSD Andrew Johnson
Next: Re: Porting EPICS to NetBSD David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
