1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VME Bus Error handling on MVME3100 and 6100 boards
To: Andy Foster <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 17 Aug 2006 09:15:19 -0500
Andy Foster wrote:
I have a note, EOL3384, from Motorola, saying that the MVME6100 is EOL pretty soon as well. Last order date, 3rd June 2007.
As Ernest said, this isn't the end of the MVME6100, just some particular model(s) of it. There will be replacements that may look a bit different but they will be functionally identical as far as the software is concerned.
You *always* have to read Motorola End Of Life notices very carefully, because they almost never mean "we're stopping all manufacture of all models of this board." The MVME147 went through about 5 or 6 different incarnations in its lifetime, moving from discrete chips to ASICs and through-hole to surface-mount construction, but in all cases the replacement models were completely software compatible with the older model. There are customers for whom the physical appearance and construction of the board matters (they may use photographs or diagrams in the maintenance manuals that they have to keep up to date), but this isn't usually the case for EPICS users.
- Andrew
Not everything that can be counted counts,
and not everything that counts can be counted.
  -- Albert Einstein
Re: VME Bus Error handling on MVME3100 and 6100 boards Andy Foster
Prev: Re: VME Bus Error handling on MVME3100 and 6100 boards Ernest L. Williams Jr.
Next: Re: VME Bus Error handling on MVME3100 and 6100 boards Joe Sullivan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
