1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Dev Asyn and Cygwin/Win IOCs , Modbus and scheduling.
To: Tech-Talk <[email protected]>
Date: Fri, 18 Aug 2006 14:27:10 -0500
What I am actually looking to do is well suited to SNL,
    I am scheduling the path a product will take through a production
line, starting with input bins and ending in output bins.
    Each step in the production functions independataly and is
controlled by some form of low level controller, in some cases that is
an EPICS iOC, but in most cases it it a vendor supplied software package
with high level hooks, typically a stringout and two Bi/Bo records.
    If the process was static or semi static I could schedule it using
SNL and have no issues at all, But the process is VERY dynamic, changing
as much as 3 time in an 8hr day. So I need a way to control the sequence
of events that is easy and rapid to program.
    I have looked at using SEQ or SSEQ records, but the any way i have
been able to think of to model the process has be requiring a new
instance of the seq record for each piece going through the system. And
well, until we get a dynamic database loader that is out.
    I was considering possibly writing a GUI State editor and doing some
sort of compile on the fly state programs, but that seems like, well, a
lot of work.
    The real killer is that the only thing that is fixed in the entire
system are the records in my database, how they connect and in what
order is entirely dynamic.
--Bill
Tim Mooney wrote:
> Bill Nolan wrote:
>> Hi all,
>>     Has anyone had experience with using DevAsyn on a win/cygwin based
>> IOC's ? was it good, bad ?
>>     Second, Has anyone worked with Modbus-TCP and the Phoenix contact
>> controllers ?
>>     And lastly has anyone done any work at all with dynamic sequences or
>> runtime editable sequences or event scheduling.
> I'm not sure what you mean by the last item.  I gather you're talking
> about something beyond the capability of the seq and sseq records.
> (sseq is seq extended to handle strings or numbers, and, optionally, to
> wait for processing completion between sequence steps.)
> The synApps std module also has something called the 4step database,
> which performs up to four user-programmable control actions, each
> followed by a completion wait, and by user-programmable read and
> calculate actions.
Re: Dev Asyn and Cygwin/Win IOCs , Modbus and scheduling. Tim Mooney
Dev Asyn and Cygwin/Win IOCs , Modbus and scheduling. Bill Nolan
Prev: Re: VCCT and CA sniffer Ernest L. Williams Jr.
Next: Re: Dev Asyn and Cygwin/Win IOCs , Modbus and scheduling. Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Dev Asyn and Cygwin/Win IOCs , Modbus and scheduling. Tim Mooney
