1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CVS Access
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Mon, 21 Aug 2006 14:38:58 -0500
Hi David,
David Dudley wrote:
Is there any way I can arrange for CVS download access of base-3.14?
As I'm making the changes to get netBSD online, would like to keep
updated with latest stuff.
For historical and security reasons we don't have a read-only CVS repository available, and read-write access is even more problematic for us. I'm hoping to switch and be able to provide access to a subversion repository at some point in the future, but that's part of a larger project which needs approval and a separate server machine (don't hold your breath). For now your best bet is to make use of one of the nightly CVS snapshots that are available - there should be no need to keep downloading it though since EPICS Base isn't change very quickly at the moment, and I don't forsee any difficulty in merging your changes back into the official release if you're working from that version, especially since you're probably only going to be adding new files.
I would not recommend using the Trunk - there are changes in there that will not see the light of day for quite a long time, and we don't guarantee that it will build. When you post your patches, we will incorporate them into both the R3.14 branch and the main trunk.
- Andrew
There is considerable overlap between the intelligence
of the smartest bears and the dumbest tourists.
  -- Yosemite National Park Ranger
CVS Access David Dudley
Prev: CVS Access David Dudley
Next: Re: VCCT and CA sniffer Matthieu Bec
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: CVS Access David Dudley
