1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: netBSD Port
To: <[email protected]>
Date: Tue, 22 Aug 2006 10:38:25 -0500
Well, finally found some time to start working on a netBSD port, and have a little 'mystery' that shows just how dense I am at some things.
I've got the CONFIG files written, and I think I have to OSI stuff correct, but when I go to do a build, the system will compile the libCom list of files, and then fail when it gets to the point where its trying to build the libCom.so.3.14 file itself.   I have the libCom.a file correctly created, but I assume I am not sending the proper commands to g++ for generating the libCom.so.3.14 file.  Sorry, but you use the G++ compiler to create a .so file?  Anyone know of an article or something covering how to do that?  or just a suggestion of the right options to pass?
David Dudley
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Prev: Re: VCCT and CA sniffer Rok Sabjan
Next: Re: VCCT and CA sniffer Brad Cumbia
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CVS Access David Dudley
Next: NetBSD Port David Dudley
