Hi Martin,
We have recently installed several MAXv cards into the sector 30 beamline
here at the APS. In one crate there is a mix of VME58 and MAXv boards.
In another there are only MAXv boards (6). In all cases the channels
are set
up to run steppers, with several channels having encoder support enabled.
It is nice to be able to select encoder support on a channel by channel
basis,
with a small change to a setup line in the boot file. So far the MAXv
boards
are performing well, and we are planning to add them to other beamlines as
needed. We are running EPICS 3.14.7/synApps_5.1.1.
Kurt
Kurt Goetze
APS/AES/Beamline Controls
Martin Heiniger wrote:
Dear all
do you have a "MAXv Multi-Axis Motion Controller"* from Pro-Dex (OMS)
in use? What is your experience?
I have seen the 2 entries from Ronald L. Sluiter and Jens Eden in the
Tech-Talk archive.
Thanks for any feedback and best regards,
Martin
*) http://www.omsmotion.com/product_detail.php?prodid=8
- MAXv Multi-Axis Motion Controller in use? Martin Heiniger
Re: Setting option flags for building system libraries David Dudley
Any EPICS support for ICS 145? Steve Lewis
<2006>
2025
2026
Re: MAXv Multi-Axis Motion Controller in use? Jens Eden
<2006>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
