1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VME Bus Error handling on MVME3100 and 6100 boards
To: Till Straumann <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 23 Aug 2006 17:00:40 -0500
Till Straumann wrote:
I know about one device that will perform 97 bus accesses inside its ISR if it gets all-1s from its read cycles.
This driver should probably be rewritten. That many VME accesses from an ISR introduce serious latencies (even w/o bus timeouts).
Ah, but in normal operation it probably only performs 4 or 5 bus accesses at most; the problem comes if it thinks (from erroneous all-1s return values when reading its status registers) that it needs to do I/O on every one of its input and output channels. This could very easily happen if someone hot-swapped out a VME64 IPAC carrier board the device was mounted on (which shouldn't happen since this driver is not hot-swap safe, but it might still occur by mistake).
I agree that this is probably a bit of a straw man argument, but it illustrates the possible consequences of the Motorola + Tundra + Marvell design decisions on our existing software.
Anyone interested in MicroTCA to replace the now aging VMEbus?
- Andrew
There is considerable overlap between the intelligence
of the smartest bears and the dumbest tourists.
  -- Yosemite National Park Ranger
VME Bus Error handling on MVME3100 and 6100 boards Andrew Johnson
Re: VME Bus Error handling on MVME3100 and 6100 boards Kate Feng
Re: VME Bus Error handling on MVME3100 and 6100 boards Till Straumann
Re: VME Bus Error handling on MVME3100 and 6100 boards Andrew Johnson
Prev: Re: VME Bus Error handling on MVME3100 and 6100 boards Till Straumann
Next: NOBUGS 2006 conference at Lawrenece Berkeley Laboratory October 2-4 Chris Timossi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: VME Bus Error handling on MVME3100 and 6100 boards Kate Feng
