I noticed that the ezca library does not recognize ENUM as a valid data
type. One can work around that by telling it to use a SHORT instead. If
we get the data type from the field itself, it is then necessary to wrap
the ezca call and trap ENUMs and make the switch to SHORT. I had trouble
when trying to post monitors on ENUM fields, such as the CNT field in
the scaler record. the ezcaNewMonitorValue function tries hard to
guarantee valid data is received by simply returning true if any error
occurs. The idea is that this forces the application to make a read,
whether it's needed or not. I was using this function to wait for
counting to be done before retrieving scaler contents. Given that CNT is
an ENUM, and ezcaNewMonitorValue treats this as an invalid data type, it
always returns true, defeating my logic. I resorted to posting the
monitor on the scaler contents instead, which worked fine. It would seem
that ezca should be modified to include this data type, or is there a
reason this isn't practical?
Pete.
- Re: ezca and ENUM Andrew Johnson
Re: VCCT and CA sniffer Rok Sabjan
Re: VME Bus Error handling on MVME3100 and 6100 boards Kate Feng
<2006>
2025
2026
Re: EPICS driver support for Oxford Cryosystems 700 Series Cryostream David Maden
<2006>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
