1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: NetBSD Port
To: "'David Dudley'" <[email protected]>, "'tech talk'" <[email protected]>
Date: Thu, 31 Aug 2006 14:54:26 -0600
> Note that unfortunately there are two CA servers in EPICS:
> The one under base/src/cas (used by excas)
> and the one under base/src/rsrv (used by the IOC).
> I hope that once you figure out how to fix one,
> you'll also know how to fix the other for netbsd.
Nevertheless, both of them rely on the same code snippet for default
initialization of the client and server address lists.
See the definition of ifreq_size for your OS. This is in
src/libCom/osi/os/XXXX/osdSock.h. We have only two versions of ifreq_size
conforming to the two different versions of this particular API that we have
seen.
Version for newer systems (probably originating from NetBSD):
#define ifreq_size(pifreq) (pifreq->ifr_addr.sa_len +
sizeof(pifreq->ifr_name))
Version for older systems:
#define ifreq_size(pifreq) (sizeof(pifreq->ifr_name))
If that doesn't work one might also replace the complete implementation in
src/libCom/osi/os/default/osdNetIntf.c with something else, but that level
of effort hopefully isn't necessary for NetBSD as Darwin is already working
with the more complex version of ifreq_size.
The server's address list can be seen if one types "casr 100" into the IOC's
command line.
Jeff
Re: NetBSD Port Kay-Uwe Kasemir
Prev: Re: Fedora Core 6 to drop OpenMotif Kay-Uwe Kasemir
Next: Re: NetBSD Port David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: NetBSD Port Kay-Uwe Kasemir
