1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: OSI Replacement for rebootHookAdd ???
To: Eric Bjorklund <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 01 Sep 2006 17:41:24 -0500
Eric Bjorklund wrote:
Personally, no, I am neither reluctant or unable. But I am working on drivers that will be distributed to lots of other sites (which is why I am in to portability these days) and I can't vouch for their situations. Plus there is just the general inelegance of requiring a special BSP patch in order for our "portable" routines to run.
So I guess the question remains -- would it be reasonable to register the exit handler with rebootAddHooks in the event that sysAtReboot is not found?
The problem with the fallback solution that you propose is that it will only work with some drivers, and not with any that make use of the vxWorks network stack because the network gets shutdown before any regular rebootHook routines are called.
A site that really can't modify their BSP can put the following (untested) line in their st.cmd file instead:
rebootHookAdd(epicsExitCallAtExits)
I think our position should be that any site that wants the proper cleanup behaviour should install the BSP patch. Adding the qualifier "but if you don't have any network devices you don't need to" will just cause the site to have to solve the problem at a later date when they *do* add a network device. IMHO the right place to fix the problem is to force it to come up early, rather than adding code to work around it that doesn't completely solve it.
We have other facilities in EPICS that don't work on an unpatched vxWorks BSP:
* the 'veclist' command won't show anything useful on most unmodified PowerPC BSPs because it uses intVecGet() which is not implemented by the WRS BSPs (in this case though it's not that useful even on a modified BSP since it can only show the first ISR in the chain for each interrupt vector; I would like to remove veclist completely from EPICS, its functionality really belongs in the BSP).
* The devLibA24Malloc subsystem relies on BSP provided routines on CPUs which don't export the whole of RAM to the A24 space (which covers every current VME CPU board from Motorola); this subsystem probably isn't used much any more, but it is a documented part of devLib that is needed for some hardware to work.
However I realize that my position may seem a bit hard-line, and if the concensus reached by discussion here is to install Eric B's workaround I will do so.
Discuss... (but enjoy the Labor Day weekend first if you're in the US!)
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
Re: OSI Replacement for rebootHookAdd ??? Eric Bjorklund
Re: OSI Replacement for rebootHookAdd ??? Andrew Johnson
Prev: Re: OSI Replacement for rebootHookAdd ??? Eric Bjorklund
Next: Re: Knob Controls Eric Bjorklund
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: OSI Replacement for rebootHookAdd ??? Eric Bjorklund
