1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: A question concerning rset->special()
To: [email protected]
Cc: [email protected]
Date: Wed, 06 Sep 2006 09:53:36 -0500
Benjamin Franksen wrote:
can the record support special() routine find out how many (array) elements have been resp. are going to be written (assuming SPC_MOD is set for the field and there is actually more than one element etc..)? And if yes, how?
No, the arguments to the rset->special() routine are the DBADDR for the field that is being written to, and the pass (0 before, 1 after the actual put operation).
However if there's more than one element in the buffer and the field is marked as special, immediately after calling rset->special() the rset->get_array_info() routine is called to get the offset value (for appending data to circular buffers), and after changing the array the rset->put_array_info() routine is also called to tell it how big the request was. Unfortunately this doesn't seem to provide any way to reject a put based on size if that's what you're trying to do.
The code that implements this is dbPut() in src/db/dbAccess.c which should be reasonably easy to follow.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
Re: A question concerning rset->special() Benjamin Franksen
Prev: Re: Device with INP as a PV_LINK Andrew Johnson
Next: Re: Device with INP as a PV_LINK Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: A question concerning rset->special() Benjamin Franksen
Next: Re: A question concerning rset->special() Benjamin Franksen
