1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS source Documentation
To: "David Dudley" <[email protected]>, <[email protected]>
Date: Fri, 8 Sep 2006 13:30:01 -0700
As the quote is mine - I'll just say that I could not agree more.
-----Original Message-----
Sent: Friday, September 08, 2006 12:54 PM
To: [email protected]
I will agree, "... Code always tells the truth.  Comments sometimes do not...".
However, a little comment block here and there, saying something along the line of "... in this block, the code is intended to do <such - and -such...>, that sort of points you in the direction of where you want to go, even if the comment is not 100% direct, would be useful most of the time.
I've seen situations where there will be some involved, intricate, block of code that maybe does a specific function (and perhaps exactly the function I'm looking for), but the functioning of the block might be obscure or embedded in the actual structure of the code.  Having a comment that says "... here the routine is going to open the door..." or something that just gives a pointer to what is going on - obviously can't be entirely bad.
Just a note on Friday afternoon......
David Dudley
>>> "Dalesio, Leo `Bob`" <[email protected]> 09/08/06 11:45 AM
As the question must not be serious -
I'll state the obvious......
Documentation says how to use it.
Reading the code tells you how to modify it.
It is good practice for the comments to at least get you to the modules and subroutine that you are looking for. Once inside - you get what you get.
Personally, I write comments for me - I have a short memory.
There are very talented programmers that have done a lot of the base code, that do not trust anything but the code. They would read the code regardless of the presence of comments. They obviously don't need comments.
RE: EPICS source Documentation David Dudley
Prev: RE: EPICS source Documentation David Dudley
Next: Re: EPICS source Documentation Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
