1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Setting MEDM window title
To: [email protected]
Date: Mon, 16 Oct 2006 18:50:16 +0100
Dear all
I was wondering: do all sites using MEDM end up having the
name of the medm source files (ie *.adl) as the titles of their
X-window displays or is there some way to avoid/override this
behaviour ?
I can see one advantage in the current implementation is that
there is never any doubt as to the source of a MEDM display.
However, as has been highlighted by one of our astronomers who
wants to change the title, what is convenient from a software
maintenance point of view is not always optimal from the point
of view of the user experience.
So far I have:
  a) tried to invoke medm using the standard X window -title option
  b) had a bit of a flirt with changing some of the settings in
     my .Xdefaults file
  c) looked at a previous solution described in tech talk here:
http://www.aps.anl.gov/epics/tech-talk/2006/msg00884.php
Unfortunately the solution described in (c) only seems to be supported under linux (xprop -set doesn't work on our Solaris platform).
Any ideas as to other solutions/workarounds would be much
appreciated.
Simon Rees
Isaac Newton Group of Telescopes
Re: Setting MEDM window title Emmanuel Mayssat
Prev: Re: epics driver for SRS RGA100 Mohan Ramanathan
Next: Re: Setting MEDM window title Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Make error after "makeBaseApp.pl" on win32-x86 Andy Foster
