1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: R 3.14.8.2 on FreeBSD 6.x amd64
To: [email protected]
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 24 Oct 2006 07:57:04 -0400
On Tue, 2006-10-24 at 13:43 +0900, Artem Kazakov wrote:
> Just if someone is interested, I'm using EPICS on Freebsd 6.x-amd64
> It just works fine. For now I have been playing with epics on FreeBSD
> for about 8 month and had no problem.
> So if anyone wants to use EPICS & FreeBSD I can share my "configure/*"
> files needed to build.
> Also, may be you can write somewhere on the web-page that EPICS &
> FreeBSD can work together :)
Are you running EPICS in pure 64-bit mode?
That is did you build EPICS as a 64-bit package or are you in 32-bit
mode?
If you are truly running pure 64-bit, you should run all of the
regression tests in EPICS BASE.  Also, you should check the EPICS
extensions.
I have been running pure 64-bit EPICS on RHEL WS4 AMD64 for about 8
months as well.
All of the regression tests pass for me.
The main problem I have now is with some of the EPICS extensions at run
time.
   --- alh (seg faults at run time)
   --- StripTool (seg faults)
   --- EDM  (works)
   --- probe (works)
   --- Channel Archiver (works)
Ernest
> Tyoma.
Re: R 3.14.8.2 on FreeBSD 6.x amd64 Artem Kazakov
Prev: R 3.14.8.2 on FreeBSD 6.x amd64 Artem Kazakov
Next: problem about importing sca to delphi marco_hair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: R 3.14.8.2 on FreeBSD 6.x amd64 Artem Kazakov
