1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ant problem when building Irmis
Date: Fri, 03 Nov 2006 10:37:40 +0100
Although being an Epics beginner, I would like to perform an evaluation of the Irmis package.
When I run "ant deploy" on the db directory, I get the following errors during the Java compilation :
compile:
[javac] Compiling 87 source files to /home/epics1/Irmis/irmisBase/db/build/classes
[javac] /home/epics1/Irmis/irmisBase/db/src/db/java/gov/anl/aps/irmis/persistence/DAOContext.java:18: error: ne peut repérer
le package par défaut « javax.crypto ». Vérifier la variable d'environnement CLASSPATH et l'accès aux archives.
[javac] /home/epics1/Irmis/irmisBase/db/src/db/java/gov/anl/aps/irmis/persistence/DAOContext.java:12: error: Class or interfa
ce `javax.xml.parsers.ParserConfigurationException' not found in import.
[javac] import javax.xml.parsers.ParserConfigurationException;
[javac] ^
[javac] /home/epics1/Irmis/irmisBase/db/src/db/java/gov/anl/aps/irmis/persistence/DAOContext.java:61: error: Type `SecretKeyS
pec' not found in the declaration of the local variable `skeySpec'.
[javac] SecretKeySpec skeySpec = new SecretKeySpec(key.getBytes(), "Blowfish");
[javac] ^
[javac] /home/epics1/Irmis/irmisBase/db/src/db/java/gov/anl/aps/irmis/persistence/DAOContext.java:62: error: Type `Cipher' no
t found in the declaration of the local variable `cipher'.
[javac] Cipher cipher = Cipher.getInstance("Blowfish");
[javac] ^
[javac] /home/epics1/Irmis/irmisBase/db/src/db/java/gov/anl/aps/irmis/persistence/DAOContext.java:64: error: Type `CipherInpu
tStream' not found in the declaration of the local variable `cis'.
[javac] CipherInputStream cis = new CipherInputStream(fileInputStream, cipher);
[javac] ^
[javac] /home/epics1/Irmis/irmisBase/db/src/db/java/gov/anl/aps/irmis/persistence/DAOContext.java:71: error: Type `DocumentBu
ilderFactory' not found in the declaration of the local variable `docBuilderFactory'.
[javac] DocumentBuilderFactory docBuilderFactory = DocumentBuilderFactory.newInstance();
[javac] ^
[javac] /home/epics1/Irmis/irmisBase/db/src/db/java/gov/anl/aps/irmis/persistence/DAOContext.java:72: error: Type `DocumentBu
ilder' not found in the declaration of the local variable `docBuilder'.
[javac] DocumentBuilder docBuilder = docBuilderFactory.newDocumentBuilder();
[javac] ^
[javac] /home/epics1/Irmis/irmisBase/db/src/db/java/gov/anl/aps/irmis/persistence/DAOContext.java:91: error: Type `ParserConf
igurationException' not found in the declaration of the local variable `pce'.
[javac] } catch (ParserConfigurationException pce) {
[javac] ^
[javac] /home/epics1/Irmis/irmisBase/db/src/db/java/gov/anl/aps/irmis/persistence/DAOContext.java:103: error: Type `NoSuchPad
dingException' not found in the declaration of the local variable `nspe'.
[javac] } catch (NoSuchPaddingException nspe) {
[javac] ^
[javac] 9 errors
(The first error message -in french- says that the "javax.crypto" package can't be found and that I have to check the CLASSPATH environment variable).
As it is the first time I am using ant, I suspect I am missing something but I don't see what : I checked that JAVA_HOME, ANT_HOME and PATH are correctly set ; then, I verified that if doing a standard Java compilation (not using ant), it compiles correctly and for example finds the missing "javax.crypto" package. I came along the ant web site but don't see there any way to solve the problem ; finally, I tried to understand the build.xml configuration file without finding any clue.
By the way, when using ant, is the CLASSPATH environment variable used, or is the classpath /only/ built from the configuration build.xml file ?
Thanks in advance for any help
Eric Lécorché
begin:vcard
fn;quoted-printable:Eric L=C3=A9corch=C3=A9
n;quoted-printable:L=C3=A9corch=C3=A9;Eric
org:Ganil;Groupe Informatique Machine
adr:;;BP 55027;Caen;;14076;France
email;internet:[email protected]
title:DBA / resp. GMAO / CC Ganil
tel;work:02 31 45 47 35
tel;fax:02 31 45 47 28
url:http://www.ganil.fr
version:2.1
end:vcard
ant problem when building Irmis (cont'd) Lecorche Eric
Re: ant problem when building Irmis Claude Saunders
Prev: Re: Multihomed IOC Maren Purves
Next: ant problem when building Irmis (cont'd) Lecorche Eric
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Multihomed IOC Jeff Hill
