Eric Norum wrote:
All my memories of GPIB horrors are returning.
I've put together ASYN/devGPIB support for an (obsolete) HP8116A signal
generator. I'm trying to communicate with the generator through an
Agilent E5810A GPIB/LAN adapter. As far as I can tell I'm sending the
correct strings but the generator never acts upon the commands. Every
once in a very long while it will return a status message in response
to a command, but most of the time it just sits there. Once in a while
it sets the SRQ line and then leaves it set forever.
Does anyone out there have experience with HP8116A GPIB communication?
Hi Eric,
I have no experience with the HP8116A, but I do have quite a bit of
experience of GPIB devices in general and the Agilent E5810A in particular.
My experience has been that HP devices have well behaved GPIB interfaces
(not surprising really, since HP invented the GPIB).
I would suggest that you first try to understand how to communicate with
your device using basic RPC calls to the E5810A before trying to tackle the
complications of ASYN/devGPIB. You may find the program described at:
<http://www.sls.psi.ch/controls/help/howto/gpib_test.html>
of some use when doing this, though I'm afraid that it won't help with SRQ
issues. It is based on routines originally written by Benjamin Franksen of
BESSY. You can find the code at:
<ftp://ftp.psi.ch/PSI_outgoing/maden/gpib_test.tar.gz>
David Maden, SLS
- Re: HP8116A signal generator Eric Norum
- Re: HP8116A signal generator Till Straumann
- HP8116A signal generator Eric Norum
ant problem when building Irmis (cont'd) Lecorche Eric
<2006>
2025
2026
<2006>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
