1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Segment fault for edm 1-11-0s
To: Dirk Kraemer <[email protected]>, [email protected]
Date: Mon, 20 Nov 2006 12:25:25 -0500
Dirk,
Try appending "<tab>exact" (where <tab> is the TAB character, ^i, to the
end of each font specification in fonts.list.
For example, change
helvetica=-*-helvetica-(medium,bold)-...
(r,o)-normal--0-(80,100,120,140,180,240,...
320,480,720)-75-75-p-0-*-*
to
320,480,720)-75-75-p-0-*-*	exact
(Note that each font spec above must be a single line)
Then run edm and see if there are missing fonts. Perhaps include only
one font at a time in fonts.list.
You may also do xlsfonts | more to examine fonts installed on your
system.
Normally, X will substitute another font for a missing one if you leave
out the "exact" option, but it seems that with FC5, something is amiss.
John
On Mon, 2006-11-20 at 12:50 +0100, Dirk Kraemer wrote:
> Hello all,
> I have a problem with EDM. If I start EDM ,then
> I see for a moment the message  "loading fonts" and a moment later
> I get the message "segmentations fault".
> I am running EDM on :
> - Fedora 5
> - gcc 4.1.0-3.i386
> - Epics 3.14.8.2
> - openMotif 2.3.0-0.1.9.i386
> - edm 1-11-0s
> I hope that someone can help me. It's the first time
> that I get this fault.
> Regards
> Dirk Kraemer
Attachment: smime.p7s
Description: S/MIME cryptographic signature
RE: Segment fault for edm 1-11-0s Peng, Sheng
Segment fault for edm 1-11-0s Dirk Kraemer
Prev: Re: Segment fault for edm 1-11-0s Ernest L. Williams Jr.
Next: RE: Segment fault for edm 1-11-0s Peng, Sheng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Incorrect display of Y label of X-Y Graph in edm Jianguo DING
