1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Naming conventions for devices and Epics records (more ...)
To: Lecorche Eric <[email protected]>
Cc: [email protected]
Date: Thu, 23 Nov 2006 09:57:42 -1000 (HST)
Eric,
I do find this question relevant, and we name these records just like
you suggest. I wouldn't be too concerned whether an operator who may
at some point see records like that understands what e.g. a calcout
is, you can documents what the record means when the time comes.
HTH,
Maren
On Thu, 23 Nov 2006, Lecorche Eric wrote:
To be clearer, for example, if I consider the so-called device "LEB1-G-Q12" (Quad 12 of LEBT 1 to guide the beam), I could therefore define "LEB1-G-Q12:Current" or "LEB1-G-Q12:Status." Let us imagine that to implement the device I must introduce internal records (calc, fanout ...) : is it a good approach to name them "LEB1-G-Q12:IntCalc1", LEB1-G-Q12:IntCalc2","LEB1-G-Q12:IntFanout1" ("Int" for "Internal record") ? And how can I solve the case when some internal record belong to the processing chains of two different devices ? Also, I am aware that if later my "internal record" has to be seen by the operator either its name becomes meaningless or I have to rename the record (without forgetting "internal" clients such as the sequencer for example ...).
Naming conventions for devices and Epics records (more ...) Lecorche Eric
Prev: Re: Ethernet electrical isolation Eric Norum
Next: Re: Naming conventions for devices and Epics records (more ...) Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Naming conventions for devices and Epics records (more ...) Lecorche Eric
