1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: m(o)ca
To: tech talk <[email protected]>
Date: Fri, 15 Dec 2006 15:43:50 -0500
Hello:
Thanks to Eric Norum and Miroslaw Dach,
the Matlab ChannelAccess client 'mca'
now also works with Octave:
Since octave is a little bit cheaper than
Matlab, that might be interesting.
On the other hand, Matlab has nicer Java
integration, so you can actually directly
use JCA/CAJ and no longer need mca...
And then there's Scilab. Too many choices!
If you're still interested in this [m|o]ca update,
you can get it by following the links
from the APS EPICS web page:
Extensions, Clients, MCA, ...
Well, except from right about now until Monday,
when power outages at the SNS will cause the
final web page to be inaccessible.
-Kay
Prev: Re: Problems with database breakpoint routines. Andrew Johnson
Next: USB interface with EPICS Kevin M. Peterson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Parker motor controllers Coles Sibley III
