The only point here is that these little USB motor controllers are very
attractive for micropositioning of optical systems, they fit nicely with
most optical accessories and are small, including the controller module
which is designed not to get in the way when mounted on an optical
bench. Motorized micrometers are slow by definition, so who cares if the
interface is not super-snappy? It would be nice to have them as part of
the scientist's toolkit within the EPICS framework. THere are also USB
CCD cameras which are relatively inexpensive. No, USB is not the answer
to all, but more and more stuff comes with it.
Pete.
Till Straumann wrote:
Eric Norum wrote:
True, devices on the USB can not make unsolicited requests for
service. But that's not a show-stopper. Consider all the GPIB
devices in use which do not use the SRQ line -- the situation in that
case is quite similar.
USB controller chips do have interrupts so it's not necessary for a
device driver to continuously poll some register in the controller to
see when a message has arrived.
True - I just wanted to make the point that this in some
cases [when low-latency is critical] could be a show-stopper
for USB.
T.
On Dec 18, 2006, at 4:06 PM, Till Straumann wrote:
Just a side note before becoming excited about USB:
AFAIK (but I could be wrong), USB has no real interrupts
but always works in some sort of 'polled' mode. There could
be latency issues with USB devices if you need really fast response.
-- Till
Chestnut, Ronald P. wrote:
Kevin,
At SLAC, one of the RF physicists started using USB. To keep matters
simple, he developed subroutines with which he could write to and
read from USB. We then hook these in with subroutine records when
time comes to put EPICS on it.
I'd also like to see some real USB driver-supported stuff.
Ron Chestnut
-----Original Message-----
From: Kevin M. Peterson [mailto:[email protected]] Sent: Monday,
December 18, 2006 7:44 AM
To: tech-talk
Subject: USB interface with EPICS
Is anyone using the USB interface with EPICS? Of particular
interest is the ThorLabs APT series.
Kevin Peterson
[email protected]
--Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- Re: USB interface with EPICS Kate Feng
- RE: USB interface with EPICS Chestnut, Ronald P.
- Re: USB interface with EPICS Till Straumann
- Re: USB interface with EPICS Eric Norum
<2006>
2025
2026
<2006>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
