1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: question about alh
Cc: [email protected]
Date: Wed, 03 Jan 2007 10:17:37 -0500
Luedeke Andreas wrote:
> 王伟珍 wrote:
>> In alh, is there other sounds besides beeping when alarms are present. i.e can I set one sound for alarm minor severity, and another sound for major severity. And can the sound last a certain time then stop automatically?
> Hi 王伟珍,
> there is no direct feature of the alarmhandler to support for
> a) playing a different sound depending on the alarm severity or
> b) to stop the acoustic alarm after a certain time.
> But as Maren pointed out, you can launch commands on severity change.
> To set a command for all channels of a group, you need to put after the
> group definition:
> GROUP NULL Linac-Magnets
> $SEVRCOMMAND UP_INVALID ca_put ALIMA:ALARM 3
> $SEVRCOMMAND UP_MAJOR ca_put ALIMA:ALARM 2
> $SEVRCOMMAND DOWN_MAJOR ca_put ALIMA:ALARM 2
> $SEVRCOMMAND UP_MINOR ca_put ALIMA:ALARM 1
> $SEVRCOMMAND DOWN_MINOR ca_put ALIMA:ALARM 1
> $SEVRCOMMAND DOWN_NO_ALARM ca_put ALIMA:ALARM 0
> You would need a server application that handles the beeping.
> But this is a clumsy solution, because if you acknowledge the alarm, it
> will have no influence on the beeping.
> Of course you can have another panel to stop the beeping.
> At the SLS we have a similar scheme to provide "Alarm area overview
> screens":
> each major group writes the alarm state to a channel like in the example
> above.
> We run into problems if several instances of the same alarmhandler
> configuration are started and if alarms are disabled in one instance and
> not in the other.
> If someone has a solution that handles alarm acknowledgements and/or
> multiple alh instances, I would be interested.
> Happy New Year!
> Andreas
We have been working on a system (for some time now) that handles
acknowledgments and multiple instances by adding a "$UASEVRPV" command
to the alh configuration. This allows a GROUP to set a PV based on the
highest unacknowledged severity in the group. We are still having some
problems with it so I have not released it.
It would still require a separate PV monitoring program to actually
sound the alarms as desired here.
Brian S. Bevins, PE
Computer Scientist / Mechanical Engineer
Thomas Jefferson National Accelerator Facility
     "Progress, far from consisting in change,
      depends on retentiveness. Those who cannot
      remember the past are condemned to repeat it."
                                         -- George Santayana
question about alh 王伟珍
Re: question about alh Luedeke Andreas
Prev: Next EPICS Meeting ? Darrell Nineham
Next: Re: Next EPICS Meeting ? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: question about alh Luedeke Andreas
Next: Another SLAC LCLS job has been posted Chestnut, Ronald P.
