1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: I have a question about using muti IOC
Cc: Luedeke Andreas <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Thu, 04 Jan 2007 18:25:47 +0100
Am I confusing this with multiple CA Gateways on one Linux box? Stupid me. But it would be nice, wouldn't it?!
Dammit. I have to think...
Well ... actually we're using multiple VMware virtual machines (probably linked clones), which have one IP address each and run one softIOC each. That's the layer in-between that I was missing.
I'm sorry.
Ralph
Andrew Johnson wrote:
Ralph Lange wrote:
I still prefer having different IP addresses for different IOCs on the same host, as you can find out a lot easier which soft IOC a certain channel (that an external CA client is connected to) resides on. Useful when things are hanging and you want to know which of the soft IOCs has to be rebooted.
How do you get the IOC (which still uses the old RSRV server, not CAS) to bind to only one particular IP address?
RSRV doesn't make use of the EPICS_CAS_INTF_ADDR_LIST variable for anything other than its CA beacon addresses, it still listens for client connections on all interfaces it can find. If those interfaces are on different subnets then this won't generally be a problem (except for client programs that are running on that same machine), but for two IPs on the same subnet this ought to give "duplicate PV" errors to all clients that try to connect to that IOC.
Am I missing something?
- Andrew
Re: I have a question about using muti IOC Ralph Lange
Re: I have a question about using muti IOC Andrew Johnson
Prev: Re: I have a question about using muti IOC Andrew Johnson
Next: Re: [No Subject] Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: I have a question about using muti IOC Emmanuel Mayssat
