1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: soft IOC string and array records
To: [email protected]
Date: Fri, 05 Jan 2007 14:06:14 -0600
At Fermilab, several of us are working on the data acquisition for NOvA, a future neutrino experiment. We would like to use process variables in soft IOCs to pass string messages between processes in the system, and we are trying to understand the best way to accomplish this.
With EPICS Base R3.14.8.2, we have experimented with string and waveform records and have noticed that messages are not always delivered to monitor processes when the messages are quickly written to the PV. I'll include some of the details of our tests below, but the central issue seems to be illustrated by the following snippet of code from db_post_single_event_private in dbEvent.c:
    * if we have an event on the queue and we are
    * not saving the current value (because this is a
    * string or an array) then ignore duplicate
    * events (saving them without the current value
    * serves no purpose)
   if (!event->valque && event->npend>0u) {
       UNLOCKEVQUE(ev_que)
       return;
I don't understand all of the ramifications of this code comment, but it certainly sounds like fast updates to string and array records are not all expected to be delivered. So, the question becomes: if we want updates to a string or waveform record (or something similar) to *always* be delivered to monitors, what are our options? We have casually used CA servers when first learning EPICS, but have not yet investigated whether they have this same feature. Are CA servers an option? Or are there established ways to select the delivery of all updates in a soft IOC?
The tests that we ran used a soft IOC created with 'makeBaseApp.pl -t ioc' and database records like the following:
record(stringout, "test1/sampleString") {
   field(DTYP, "Soft Channel")
record(waveform,"test1/sampleWaveform") {
   field(DTYP,"Soft Channel")
   field(NELM,"32")
   field(FTVL,"UCHAR")
To update the PV value at a reasonably high rate, we simply made a copy of caput.c and added a loop around the writing of the data as shown below (the modification of the first character in the sbuf/pbuf array allowed us to check for missing or duplicate records when observing the updates with a camonitor client):
for (idx = 0; idx < 100; idx++) {
sprintf(sbuf[0], "%d", idx);
result = ca_array_put (dbrType, count, pvs[0].chid, pbuf);
result = ca_pend_io(caTimeout);
if (result == ECA_TIMEOUT) {
fprintf(stderr, "Write operation timed out: Data was not written.\n");
return 1;
For the waveform record test, we started the soft IOC, ran 'camonitor test1/sampleWaveform', and then ran the modified caput several times with 'caput -a test1/sampleWaveform 5 2 4 6 8 10'. Some of the times that we ran caput, we saw all 100 messages arrive at the camonitor. Other times, only one or two of them did.
Thanks in advance for any help that folks can provide with this,
Kurt Biery
Re: soft IOC string and array records Kay-Uwe Kasemir
Re: soft IOC string and array records Tim Mooney
RE: soft IOC string and array records Jeff Hill
Prev: Re: I have a question about using muti IOC Luedeke Andreas
Next: Re: soft IOC string and array records Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [No Subject] Andrew Johnson
