1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VME-based arbitary function generator
To: Shifu Xu <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>, Ned Arnold <[email protected]>
Date: Wed, 10 Jan 2007 14:43:19 -0500 (EST)
On Wed, 10 Jan 2007, Shifu Xu wrote:
> Basically, the requirements for the arbitary function generator is as
> follows:
>  > 33 millisecond long programmable waveform triggered at 30 Hz
>  > bipolar output
>  > 10 usec time resolution (or better) (implies a memory length of > 3.3K)
>  > 1% amplitude resolution (or better) (e.g. 10-12 bits would be fine)
I'm using Joerger model VDACM waveform generators which I think meet your
requirements: 8 channels, 16-bit, +/- 10 V, memory for 32K points per
channel, 100 KHz clock. If you need better then 10 usec step size, they
also make a 100 MHz board in 12-bit but I haven't used that one.
See: http://www.joergerinc.com/VME.htm
I wrote EPICS software for the VDACM (VxWorks only at this point).
Let me know if you need more information.
Steve Hartman
[email protected] || 919-660-2650
Duke Free Electron Laser Laboratory
VME-based arbitary function generator Shifu Xu
Prev: VME-based arbitary function generator Shifu Xu
Next: RE: VME-based arbitary function generator Chestnut, Ronald P.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
