1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Out of order replies from a serial device
To: "Phillip Sorensen" <[email protected]>, "Emmanuel Mayssat" <[email protected]>
Cc: "TechTalk EPICS" <[email protected]>
Date: Fri, 19 Jan 2007 14:57:53 -0600
I believe asyn is doing the flush operation that Emmanuel suggested.
I suspect you are not getting out of order replies.  I think you are getting a timeout, but then stale data from some buffer is ending up in the apparent data you received with the timeout.
Sent: Fri 1/19/2007 2:51 PM
To: Emmanuel Mayssat
Cc: TechTalk EPICS
Subject: Re: Out of order replies from a serial device
Emmanuel Mayssat wrote:
> Before you send a command to your serial device, you should clear the
> serial buffers.
> So a read operation becomes:
> 1/ Read ( you will read nothing most of the time), this operation
> clears /flushs the serial buffers.
> 2/ send your serial commnad/inquiry
> 3/ read the serial port a second time to get your PV value
> Note that this is also assuming that you are using serial port locking,
> and that this feature is working correctly (i.e. only 1 write-read
> request at a time )
That sounds like it would work, but I am currently using the asyn
devGpib device support module framework with GPIBREAD commands.  The
framework handles the actual communications.
I can rewrite the device support to use GPIBCVTIO commands and write the
communication code myself, but I would prefer to use the devGpib code
for as much as possible.
Phil Sorensen
CHESS
Re: Out of order replies from a serial device Phillip Sorensen
Re: Out of order replies from a serial device Emmanuel Mayssat
Prev: Re: Out of order replies from a serial device Phillip Sorensen
Next: Re: Out of order replies from a serial device Phillip Sorensen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
