1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: MEDM Byte Monitor Object
To: <[email protected]>
Date: Wed, 24 Jan 2007 14:24:48 -0500
MEDM 3.1.1 supports the Byte Monitor Object in the UP and the RIGHT
directions, version 3.0.3 supports it in the DOWN and RIGHT directions
(medmByte.c).  In 3.0.3 edit mode, you can choose any of the four directions;
at runtime the invalid direction is overridden with the supported one.  The
current MEDM Manual's 'direction attribute' table says the Byte Object can
use all four directions, although the paragraph for the Byte Monitor
describes the direction limitations.
So a display created under 3.0.3 with a medmByte in the UP direction will
generate a warning (in stdout and MEDM Message Window) under 3.1.1 .  The
appearance/vertical-alignment of the 'bits' are the same for both medm's, so
it's not too disasterous.
Paul Sichta
Princeton Plasma Physics Laboratory
609-243-3477
Re: MEDM Byte Monitor Object Andrew Johnson
Prev: LivEPICS Fedora Core 5 Release v.1.0 Mauro Giacchini
Next: Re: MEDM Byte Monitor Object Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
