Michael,
I never had this problem and am not on a Windows platform, but...
I can imagine a situation where a record can have such a behavior.
For example if the PACT field of the PV is set to 1 and the value of the
text entry is "" (empty) then the PV do not update.
My advice: set the value of the record before initialization
field(VAL, "foo")
and see what happens. Most likely one of your record's field is not set
correctly at database initialization. Alternatively, if it isn't a
standard record, I would check the code of your driver.
Enjoy,
Emmanuel
On Fri, 2007-01-26 at 17:34 -0800, Michael Urashka wrote:
> Has any seen this behavior before (or have a suggestion as to what is
> going on).
> MEDM is installed as per the Windows Win32 EPICS Extension package along
> with Hummingbird Exceed 10.
> On several of the Control Room consoles, MEDM behaves normally, as it
> does on my development desktop.
> On another bunch of the Control Room consoles, MEDM launches fine but
> will not take keyboard input. One is able to
> mouse onto a new canvas and create a new object widget, a Textt Monitor
> for example. When one clicks on the "Text"
> field (or the "Channel A", "Channel B", "Width", "Height" fields) in the
> Resource Palette, one is not able to make any entries
> with the keyboard.
> I am certain I am using the correct keyboard plugged into the correct
> PCs and that the keyboards function normally in other applications.
> Any suggestions?
> Michael Urashka | Advanced Light Source
- MEDM behavior, can't type in text edit box. Michael Urashka
RE: MEDM behavior, can't type in text edit box. Mark Rivers
<2007>
2025
2026
<2007>
2025
2026
