1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MEDM behavior, can't type in text edit box.
To: "'Michael Urashka'" <[email protected]>, <[email protected]>
Date: Mon, 29 Jan 2007 09:36:53 -0600
Hi Michael,
	I have seen similar problem on my new HP Windows.  But I used Xming
package (Cygwin) instead of Exceed.  The problem, as Mark pointed out, was
the XKEYSYMDB setting.  I pointed it to the file in "EPICS Win32 Extension"
directory, which somehow didn't work for my new PC.  I found a newer version
of XKEYSYMDB in Xming (Cygwin) directory, which dated 2005 vs. 2000 for the
one in EPICS directory, and it worked.
Zhan
Zhan Zhang, Ph.D
Argonne National Laboratory
X-ray Science Division, Bldg 438, D005
9700 S. Cass Ave.
Argonne, IL 60439
Tel: (630) 252-0863
Email: [email protected]
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Friday, January 26, 2007 10:32 PM
> To: Michael Urashka; [email protected]
> Hi Michael,
> I have heard reports of this on other X servers.
> This is from the Win32 EPICS Extensions Readme.txt file:
> Note that the build Exceed version changed from 6.2 to 7.0
> with Build 32 and the behavior of Exceed 7 is different from
> that of 6.2. If you are upgrading from a build prior to Build
> 32, you should review the instructions as the installation
> has changed.  If your version of Exceed is different from the
> build version, especially if it is prior to Exceed 6.1, you
> may need to set the environment variable DISPLAY, possibly
> XKEYSYMDB, and possibly XLOCALEDIR.
> I suspect the problem is that you need to define XKEYSYMDB?
> Here is how to do it from the same Readme.txt file:
> Setting XKEYSYMDB causes Exceed to find the Keysym database
> in the EPICS WIN32 Extensions directory.  The Exceed support
> files do not need to be installed.  If you have Exceed 5,
> this will always be necessary.  It may also be necessary if
> you have another earlier version, unless you have the Exceed
> XDK.  It will also probably be necessary if you are not using
> Exceed.  If you are getting messages about unfound keysyms,
> such as osfActivate, set this variable.  If the EPICS WIN32
> Extensions are in the default location, the command is:
> set XKEYSYMDB=c:\Program Files\EPICS WIN32 Extensions\XKeySymDB
> Mark
> ________________________________
> From: Michael Urashka [mailto:[email protected]]
> Sent: Fri 1/26/2007 7:34 PM
> To: [email protected]
> Subject: MEDM behavior, can't type in text edit box.
> Has any seen this behavior before (or have a suggestion as to
> what is going on).
> MEDM is installed as per the Windows Win32 EPICS Extension
> package along with Hummingbird Exceed 10.
> On several of the Control Room consoles, MEDM behaves
> normally, as it does on my development desktop.
> On another bunch of the Control Room consoles, MEDM launches
> fine but will not take keyboard input. One is able to mouse
> onto a new canvas and create a new object widget, a Textt
> Monitor for example. When one clicks on the "Text" field (or
> the "Channel A", "Channel B", "Width", "Height" fields) in
> the Resource Palette, one is not able to make any entries
> with the keyboard.
> I am certain I am using the correct keyboard plugged into the
> correct PCs and that the keyboards function normally in other
> applications.
> Any suggestions?
> Michael Urashka | Advanced Light Source
RE: MEDM behavior, can't type in text edit box. Mark Rivers
Prev: EPICS and HEPiX Rees, NP (Nick)
Next: StreamDevice and checksum Phillip Sorensen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: MEDM behavior, can't type in text edit box. Mark Rivers
Next: EPICS and HEPiX Rees, NP (Nick)
