1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: devSymb
To: Rolf Keitel <[email protected]>
Cc: tech_talk <[email protected]>
Date: Wed, 21 Feb 2007 14:04:52 -0600
Hi Rolf,
Rolf Keitel wrote:
I am new to 3.14. Has anybody done the equivalent of the VxWorks devSymb for Linux, which would allow records to access global variables from the device support level?
I started looking at making devSymb portable in 2004 (the vxWorks code for 3.14 is in the EPICS CVS repository and downloadable from the download/modules page), but I didn't get very far with it at the time.
To get the symbol address in a portable manner I'd require that you register all your variables within a DBD file. We already allow the 'variable(name,type)' syntax in the DBD file parser, you'd also have to annotate the variable source using 'epicsExportAddress(type,name)'. This was provided to allow iocsh to read and set such variables. I'd then change devSymbFind.c to do the same lookup that iocsh does in order to find the symbol address if the call to epicsFindSymbol() fails [that's the new OSI name for symFindByNameEPICS() BTW, but maybe it should do that lookup itself. Maybe even the Linux version of epicsFindSymbol() should use the dlopen()/dlsym() routines instead?].
I started to think about the storage type of the variable, and how that maps to the record type, and at this point I stopped because I didn't want to have huge numbers of device support types for every combination of int/short/long/double vs Ai/Ao/Li/Lo/Mbbi/Mbbo/Wf record. However I think that was a bit of a red herring because the DBD variable() statement only supports int and double at the moment anyway.
I'd be happy to see an updated portable version of devSymb if you do come up with one; if you find you need any changes in base to facilitate that just let me know.
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
devSymb Rolf Keitel
Prev: Anyone using RSS/Atom? Paul Sichta
Next: Java IDE & graphic library Lecorche Eric
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: devSymb Rolf Keitel
Next: Parker GV6K support? Russ Berg
