1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Java IDE & graphic library
To: "Chu, Chungming Paul" <[email protected]>, "Larrieu, Christopher" <[email protected]>, "Kay-Uwe Kasemir" <[email protected]>
Cc: "tech talk" <[email protected]>
Date: Fri, 23 Feb 2007 16:36:13 -0800
I agree with Paul 100%.
Have a nice weekend, dudez :-)
Sergei
-----Original Message-----
From: Chu, Chungming Paul [mailto:[email protected]]
Sent: Fri 2/23/2007 4:26 PM
To: Larrieu, Christopher; Kay-Uwe Kasemir
Cc: tech talk
I used Netbeans a couple of years ago (up to v.3.5 and briefly with v.4).  Because at that time, it was not easy to run an app within the IDE using ant build.xml, I switched to Eclipse.  I think both Eclipse and Netbeans are good IDEs and both can do a lot more than Emacs (refactoring, CVS, and hundreds of other features).  They both support plug-in development, if you ever want to write plug-ins instead of stand-alone apps.  The biggest difference as an IDE (I think) is the user base -- developers using Eclipse are far more than any other IDEs (a survey done over a year ago showing ~50% of Java developers using Eclipse).  Therefore, there are a lot of existing Eclipse plug-ins you can download (for free).  And, more Eclipse books, online helps than NetBeans.  However, if you are trying to use GUI/RCP (rich client platform), it opens up another big debate between SWT/JFace (Eclipse) and AWT/Swing (pure Java?) which I don't think I'd like to get in in Friday afternoon.
As an IDE, one thing I like Eclipse in particular (besides refactoring and other features people already mentioned) is the "Call Hierarchy" view -- it shows all the call chain and you can easily understand code written by others.
I don't know if NetBeans offers similar feature in 5.5.
Paul
From: Christopher Larrieu [mailto:[email protected]]
Sent: Thu 2/22/2007 11:54 AM
To: Kay-Uwe Kasemir
Cc: tech talk
Subject: Re: Java IDE & graphic library
Can't agree more.  I've tried off and on to like the various IDE's du
jour through the years, and I always find that nothing beats good old
emacs for serious coding.
While I expect to be working with eclipse as an application platform, I
imagine I'll mostly be coding in emacs, using eclipse for the things
that it does well, like refactoring.
Chris
On Thu, 2007-02-22 at 14:26 -0500, Kay-Uwe Kasemir wrote:
> On Feb 22, 2007, at 12:06 , Claude Saunders wrote:
> >  - Claude "I don't use an IDE, but that doesn't stop me from having
> > an opinion." Saunders
> In the (distant) past, I had used Turbo Pascal, Borland C++,
> Visual Studio, KDeveloper, and every time came back
> to vi, make, emacs.
> Eclipse was the first IDE that really appealed to me
> - it doesn't force you to create your project in a specific way.
> You can locate your sources and binary in pretty much any place,
> and also import existing projects.
> - the java support is really nice: completion, compile-as-you-type
> error checking
> - the absolute killer is the refactoring.
> Not just rename classes, but extract sections of code into their
> own subroutine, extract methods into interfaces etc.
> All that is perfectly usable for plain Java code that before or after
> being edited inside Eclipse bears no mark of ever having been in
> contact with it.
> Netbeans might be similar, I don't know.
> I didn't like the Eclipse GUI interface builder.
> Maybe because it only really works well on Win32,
> maybe because I never liked any GUI interface builder.
> -Kay
Java IDE & graphic library Lecorche Eric
Re: Java IDE & graphic library Claude Saunders
Re: Java IDE & graphic library Kay-Uwe Kasemir
Re: Java IDE & graphic library Christopher Larrieu
RE: Java IDE & graphic library Chu, Chungming Paul
Prev: RE: Java IDE & graphic library Chu, Chungming Paul
Next: Re: Java IDE & graphic library tieman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
