Aloha
At Keck our IOC console ports are all
connected to terminal server ports and, typically, there is a telnet session to
each of those ports that are ‘tee’d to a log file. The reason for
this is that software bugs (typically in drivers or callbacks) will often cause
VxWorks failures which may generate messages that do not get into the iocLog
files. I suspect it should be easy to adapt the iocConsole/screen software to
deal with the terminal server sessions (thanks for that info).
Cheers,
Al
H. [mailto:[email protected]]
Sent: Thursday, March 01, 2007
10:43 AM
To: [email protected]
Subject: Serial port access and
loging services for IOCs?
Here at SNS we have lately had problems with IOCs crashing
without leaving any trail for analyzing what the problem was. We have our
own home grown procServe and we are looking into the iocConsole/screen software
that SLAC is using. We are different from SLAC in that we use Digi port
servers with a driver on one of the linux servers that maps port server ports
into local /dev/ttyXXNNN devices. We just use 'cu' to open a serial
port. IocConsole does not support that but making it do so would not be
hard I don't think.
Looks like a modified iocConsole is our best option but
before we commit to it we thought we out to see what others are doing to
capture the last few lines of terminal activity from running and crashed hard
IOCs.
- Serial port access and loging services for IOCs? Thompson, David H.
RE: Serial port access and loging services for IOCs? Jeff Hill
<2007>
2025
2026
<2007>
2025
2026
ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
