1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epics / fpga
To: Joze Dedic <[email protected]>
Cc: [email protected]
Date: Fri, 02 Mar 2007 11:03:48 -0600
thanks for your response... at this point i don't have any specific requirements/application
and only interested in finding out what has been done throughout the community.
at the moment we use an epics brick (linux-based pc104 system) running epics to communicate
with either an in-house designed external fgpa board (using the epics brick dio) or over the bus
using the fpga104 from tri-m systems.
/david
Joze Dedic wrote:
Hi David
Can you give some more details for the requirements?
Generally an OS is required to run EPICS, which requires the use of
processor. Here you have several possibilities:
- you can use soft-core processor for your FPGA circuit (for Altera that
would be NIOS)
- you can use in-FPGA hard-wired processor (Xilinx's Virtex II pro with
Motorola Power PC)
- use some standalone embedded processor and connect your FPGA circuit it
via some bus that allows you enough data throughput
One thing you should be aware of is that porting a Linux to a softcore or
hard-wired in-FPGA processor is all but trivial (despite what the Xilinx and
Altera state).
Our practice is to use embedded platform for flexibility and connect it to
the FPGA board over PC/104 bus.
For example, we have built a 500MHz delay generator, capable of producing
programmable delays with the jitter of less than 50ps, which is integrated
in EPICS. For performance we used Xilinx FPGA (thus pushing the
state-of-the-art FPGA to its edge) and for flexibility embedded platform
running Linux (that was a piece of cake because we already have the range of
solutions using embedded platforms).
Cordially,
Joze
Joze Dedic, Ph.D.
Senior Hardware Developer
Cosylab d.o.o.
Teslova ulica 30
SI-1000 Ljubljana
Slovenia
Email: [email protected]
Phone: +386 1 4776 759
Mobile: +386 41 279 232
http://www.cosylab.com
http://www.microioc.com
-----Original Message-----
Sent: Friday, March 02, 2007 2:21 PM
To: [email protected]
Subject: epics / fpga
has anyone got epics to run on an altera fpga?
thanks in advance,
/david
David M. Kline                   [email protected]
Beamline Controls and Data Acquisition (BCDA) Argonne
National Laboratory, Advanced Photon Source
Argonne IL, 60439                      630.252.8639
                   Beamlines R Us
Argonne National Laboratory, Advanced Photon Source
                   Beamlines R Us
Re: epics / fpga D. Peter Siddons
epics / fpga David Kline
RE: epics / fpga Joze Dedic
Prev: RE: epics / fpga Joze Dedic
Next: Re: Serial port access and loging services for IOCs? Theo Larrieu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: epics / fpga D. Peter Siddons
