1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Darwin and EPICS_CA_AUTO_ADDR_LIST issue
To: Jeff Hill <[email protected]>
Cc: [email protected]
Date: Fri, 09 Mar 2007 11:06:36 +0100
One more clue:
I removed the currently down nodes from the EPICS_CA_ADDR_LIST and all seems to be okay. I don't get any error messages like "host is down".
It seems to me, there is a problem in the code with the unicasts: if there are nodes on the list which do not respond (in time?) some other nodes (which are alive) are considered to be dead???
Burkhard
Jeff Hill wrote:
What is the response to "ping -s 140.181.98.50"?
PS: Behavior is known to vary between IP kernels for such unicast addresses
if there are two or more daemons (in this case two or more CA UDP servers)
listening to the same {IP address, port} tuple on the same host. The typical
behavior difference is that on certain IP kernels only one daemeon listening
on UDP port 5064 will receive a UDP message with a unicast destination
address, but in contrast on other IP kernels all daemeons listening on UDP
port 5064 will receive such messages. In my experience UDP frames with
broadcast address destinations always go to all registered listeners
listening on UDP port 5064 - a uniform behavior across IP kernel
implementations.
PPS: One possible workaround to the above dilemma is to use directed
broadcast addresses (router forwarded broadcast addresses) in the
EPICS_CA_ADDR_LIST. This sometimes requires enabling of "broadcast
forwarding" features in your routers. We might also add support for
multicasting to future versions of CA.
Jeff
-----Original Message-----
Sent: Thursday, March 08, 2007 9:28 AM
To: '[email protected]'
Subject: Darwin and EPICS_CA_AUTO_ADDR_LIST issue
On my MAC (OSX 10.4.8), EPICS base-3.14.9, medm 3.11:
When I set EPICS_CA_AUTO_ADDR_LIST to NO and have the EPICS_CA_ADDR_LIST
pointing to the list of IOCs medm does not find all PVs. Sometimes the
connections work for a short time then several IOCs are not seen anymore.
If I set it to YES, medm finds them always.
In the xterm window I get some error messages from really not existing
IOCs:
CAC: error = "Host is down" sending UDP msg to 140.181.98.50:5064
But the lost ones are not reported!
I use the same list of IOCs on other linux boxes and have no problem
there.
Any idea?
-- ------------------------------------------------------------------- Dr. Burkhard Kolb GSI mbH | KP1 | Planckstr. 1 | D-64291 Darmstadt Email: [email protected] | Tel.: +49 (0)6159 / 71 2667 -------------------------------------------------------------------
RE: Darwin and EPICS_CA_AUTO_ADDR_LIST issue Jeff Hill
Darwin and EPICS_CA_AUTO_ADDR_LIST issue Burkhard Kolb
Prev: Re: Darwin and EPICS_CA_AUTO_ADDR_LIST issue Burkhard Kolb
Next: caPutLog and Vxstats equivalent for Linux ? Jane Richards
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Darwin and EPICS_CA_AUTO_ADDR_LIST issue Jeff Hill
Next: RE: Darwin and EPICS_CA_AUTO_ADDR_LIST issue Jeff Hill
