1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with compiling Channel Archiver
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Fri, 16 Mar 2007 11:11:29 -0400
Hi:
The XML-RPC library for C/C++ has been a pain in the eyebrow.
The ChannelArchiver comes with specific versions for Linux
in general as well as OS X _plus_patches_ that allow us to pass a wider range
of 'double' type values.
Other versions have slightly different APIs and/or include files,
as you see, and that would require changes in the archiver sources.
The fact that xmlrpc-c-config gives an incomplete
"-I$(prefix)/include" looks wrong enough to me
to not even try to make the Gentoo setup to work,
and instead just use the xmlrpc-c-0.9.9.tar.gz
that comes with the archiver sources.
-Kay
On Mar 16, 2007, at 11:01 , David Dudley wrote:
OK, missed something in the manual, I guess.  Under Gentoo, I have
installed:
dev-java/xmlrpc = version 1.2_beta-r1
dev-libs/xmlrpc-c = version 1.06.03
In /usr/include, I have:
find . -name 'xmlrpc*'
./xmlrpc_server.h
./xmlrpc_server_abyss.h
./xmlrpc_cgi.h
./xmlrpc_client.h
./xmlrpc_server_w32httpsys.h
./xmlrpc-c
./xmlrpc.h
I have xmlrpc_server_abyss.h, but not a xmlrpc_abyss.h.
I do have xmlrpc-c-config in my path, but when I do the
'XMLRPCServer/xmlrpc-config-wrapper server-flags' command, I get
'-I$(prefix)/include' as a result.
Did I miss installing something?
David
<David Dudley.vcf>
Prev: Re: Problem with compiling Channel Archiver David Dudley
Next: Re: Problem with compiling Channel Archiver David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
