1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Outputting a constant value
To: "Ned D. Arnold" <[email protected]>
Cc: <[email protected]>
Date: Wed, 04 Apr 2007 11:09:20 -0500
Still no cigar (maybe that should be bubblegum - you know, to be
"politically correct" ;-)
Now, the BO is outputing to a modbus device, I have OMSL=closed_loop
and [email protected].  When the database loads, if I do a 'dbpr 2' on the
record, I can see that DISV does indeed have a 1 value, and DOL is
pointing back to it, however VAL is still zero.  Activating the record
(it's forward linked from another record) causes it to output a zero,
and the VAL still remains zero.
David Dudley
>>> "Ned D. Arnold" <[email protected]> 4/4/2007 10:13 AM >>>
David -
I seem to remember (when I actually worked with this stuff) that
setting the DOL to 1 only worked for Soft Channel BOs.  Try setting DOL
to a link that is always one (e.g. DISV or DISA of the same BO record)
and OMSL to closed_loop.  This way it will always fetch a 1 for the
output.  This eliminates the need for the extra BI record you
described.
Ned
David Dudley wrote: Unfortunately, that didn't work.In vdct, I can set
the .VAL field to 1, but when I load the db, the VALfield is 0.  Setting
DOL to 1 causes it to have a 'CONSTANT 1' valuewhen you do a 'dbpr' on
the field, and I have OMSL set to 'closed-loop',however the .VAL field
remains at 0.  If I do a forward link to theblock, it outputs a zero,
and the .VAL remains 0.  If a do a 'dbpf' toset the value to 1, it then
works fine.  What I did as a patch aroundthe questionable action was to
use a BI block with its DTYPE set to'Soft Channel' and an INP of '1'
that is linked to the BO, but seemslike a round-about way of doing such
a simple thing.I thought I was probably just missing something on the BO
block.David Dudley  "Paul Sichta" <[email protected]> 4/4/2007 9:20 AM
>>>        David,Can you set the DOL to '1' and use closed-loop control,
rather thanthedefault supervisory.
BEGIN:VCARDVERSION:2.1X-GWTYPE:USERFN:David
DudleyTEL;WORK:880-3740ORG:;MISTEL;PREF;FAX:880-3741EMAIL;WORK;PREF;NGW:[email protected]:Dudley;DavidEND:VCARD
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
N:Dudley;David
END:VCARD
Prev: Re: Outputting a constant value Tim Mooney
Next: RE: Using Groups and hierarchal design in VDCT Shepherd, EL (Emma)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Point Grey Flea2 John Dobbins
